[gdal-dev] gdalwarp skews and rotates PDF rasters, when converting to GeoTIFF, when PDF raster are in Landscape orientation or (True north facing botton or right or left)
Even Rouault even.rouault at spatialys.com
Mon Apr 20 12:27:18 PDT 2015
Le vendredi 17 avril 2015 14:43:43, Gane R a écrit :
> I am using gdal 1.10.1
> I have a set PDFs, I am converting them to GeoTIFF.
> I am using gdal with poppler for pdf  driver.
> I have PDFs of places with orientation in Landscape, and north facing right
> or left or bottom.
> When I apply a gdalwarp for these PDFs I get unexpected rotation at GeoTIFF
> output.
> I read this link too
> http://lists.osgeo.org/pipermail/gdal-dev/2014-June/039438.html
Now fixed in trunk, in the particular case provided by Gane, with OGC Best
Practice encoding and rotation = 90.
Other cases might require additional adjustments.
> I need some guidance for this. Say some kind of work flow with gdal command
> line tool will be of great help.
> Thanking you,
> Gdal gurus.
http://www.spatialys.com
