[gdal-dev] Retreivinng a table with a condition using ogr2ogr OCI
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Tue Apr 21 13:36:51 PDT 2015
Even Rouault <even.rouault <at> spatialys.com> writes:
> Le mardi 21 avril 2015 16:43:44, Jukka Rahkonen a écrit :
> > If I read the command right:
> > "ogr2ogr 3011 -f "ESRI Shapefile" OCI:"user/password <at> ... "
> > it does not follow the ogr2ogr syntax as documented in
> > http://www.gdal.org/ogr2ogr.html
> > ogr2ogr .... dst_datasource_name src_datasource_name
> Jukka,
> The target filename (directory) is 3011 in the above. Although it is
> recommanded to put options starting with a dash character before other
> options, the parser is pretty tolerant about that.
Oh no, ogr2ogr caught me unaware after nine years regular exercises on
typing those ogr2ogr and gdal_translate commands. Some freaky programmer
must be smiling.
-Jukka-
