[gdal-dev] Copy meta data from one JP2 to another JP2 C++
Even Rouault even.rouault at spatialys.com
Wed Apr 22 09:15:51 PDT 2015
Le mercredi 22 avril 2015 18:05:57, Dr. Joshua Jackson a écrit :
> So I changed my C++ code to follow the basic path of gdalcopyproj.py
> instead of copying the complete data set (see code below), and I am
> getting a separate .aux.xml file generated instead of the data being
> merged to the JP2 image file.
> Someone mentioned testing against GDAL 2.0, but as I have 1.11.2 which
> according to the GDAL web page is the latest release.
Yes, you definitely need the development version GDAL 2.0dev, unreleased yet,
and compile it from sources :
http://trac.osgeo.org/gdal/wiki/DownloadSource#Developmentversionandsourcecontrol
or use Windows binaries for the development version :
http://www.gisinternals.com/development.php
> const char *srcProjection = srcDataset->GetProjectionRef();
>     double *srcTransform;
>     srcDataset->GetGeoTransform(srcTransform);
>     int gcpcount = srcDataset->GetGCPCount();
>     const GDAL_GCP *gcps = srcDataset->GetGCPs();
>     const char* gcpProj = srcDataset->GetGCPProjection();
>     dstDataset = (GDALDataset *) GDALOpen(maskPath, GA_Update);
>     dstDataset->SetGeoTransform(srcTransform);
>     dstDataset->SetProjection(srcProjection);
>     if (gcpcount > 0) {
>         dstDataset->SetGCPs( gcpcount, gcps, gcpProj);
>     if(dstDataset != NULL)
>         GDALClose((GDALDatasetH)dstDataset);
> Joshua Jackson, PhD
> Senior ResearchEngineer
>  (800) 604-1822 Ext. 5109 <tel:8006041822,5109>   (256) 648-5109
> <tel:2566485109> josh at nside.io <mailto:josh at nside.io>   www.nSide.io
>  <http://www.nside.io/> 4031 Parkway Dr, Suite B, Florence, AL 35630
>   <http://www.linkedin.com/company/nside/>  <http://twitter.com/nSide__Out>
> > On Apr 15, 2015, at 4:06 PM, Dr. Joshua Jackson <josh at nside.io> wrote:
> > Yes.  For example original file is middle.jp2  New file is
> > middle_mask.jp2.
> > gdalcopyproj.py middle.jp2 middle_mask.jp2
> > Result is middle_mask.jp2 isn’t even modified according to OS time stamp,
> > but new file is created middle_mask.jp2.aux.xml.
> > Joshua Jackson, PhD
> >  <http://www.nside.io/> <http://www.nside.io/> 4031 Parkway Dr, Suite B,
> >  Florence, AL 35630
> >> On Apr 15, 2015, at 4:02 PM, Even Rouault <even.rouault at spatialys.com
> >> <mailto:even.rouault at spatialys.com>> wrote:
> >> Le mercredi 15 avril 2015 22:58:07, Dr. Joshua Jackson a écrit :
> >>> gdalcopyproj does not work for me because it outputs a separate xml
> >>> file instead of overlaying the data into the new image file.
> >> Weird. I've just tested it works properly with the latest GDAL trunk
> >> (2.0dev).
> >>> Joshua Jackson, PhD
> >>> <mailto:josh at nside.io <mailto:josh at nside.io>>   www.nSide.io
> >>> <http://www.nside.io/> <http://www.nside.io/ <http://www.nside.io/>>
> >>>  <http://www.linkedin.com/company/nside/>>
> >>>  <http://twitter.com/nSide__Out <http://twitter.com/nSide__Out>>
> >>>> On Apr 15, 2015, at 3:06 PM, Even Rouault <even.rouault at spatialys.com
> >>>> Le mercredi 15 avril 2015 21:46:26, Dr. Joshua Jackson a écrit :
> >>>>> I’m looking for a good solution to copy the image meta data from one
> >>>>> JP2 to another JP2 in C++.  I have a folder full of 4096x4096
> >>>>> JPEG2000 images that I am processing with OpenCV.  On some of them I
> >>>>> create a copy of the image and do some manipulations to.  As
> >>>>> expected the new image file is missing all the metadata.
> >>>>> I have tried using CreateCopy() with the OpenJPEG library; and while
> >>>>> this does work it takes a really long time per image ~40sec.  (My
> >>>>> image manipulations take only ~10sec).
> >>>>> Is there some way to use the GetGDALDataSet() on the source file and
> >>>>> then call SetMetaData() on the destination file for each meta data
> >>>>> item?  How would one iterate through the metadata items?
> >>>> The "metadata" you're talking about are more the georeferencing info,
> >>>> right ? (In GDAL "metadata" is about all other metadata, excluding the
> >>>> georeferencing)
> >>>> If you use trunk, you could likely try the new USE_SRC_CODESTREAM=YES
> >>>> creation open of the jp2openjpeg driver
> >>>> Something like:
> >>>> gdal_translate your_jp2_without_georef.jp2 out.jp2 -co
> >>>> USE_SRC_CODESTREAM=YES -a_srs EPSG:4326 -a_ullr  -96.9653320
> >>>> 32.4645996 -96.9598389 32.4591064
> >>>> The SetGeoTransform() and SetProjection() API also do something
> >>>> similar internally, so you could also do :
> >>>> gdal_edit.py your_jp2_without_georef.jp2 -a_srs EPSG:4326 -a_ullr
> >>>> -96.9653320 32.4645996  -96.9598389 32.4591064
> >>>> or more conveniently:
> >>>> gdalcopyproj.py middle_mask.jp2 out.jp2
> >>>> (http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/gdalcopyproj
> >>>> .py
> >>>> <http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/gdalcopypro
> >>>> j.py>
> >>>> j.p
> >>>> j.p> y>)
> >>>> Even
> >>>>> Here is a sample GDALInfo printout for a source image:
> >>>>> Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
> >>>>> Files: middle_mask.jp2
> >>>>> Size is 4096, 4096
> >>>>> Coordinate System is:
> >>>>> GEOGCS["WGS 84",
> >>>>>   DATUM["WGS_1984",
> >>>>>       SPHEROID["WGS 84",6378137,298.257223563,
> >>>>>           AUTHORITY["EPSG","7030"]],
> >>>>>       AUTHORITY["EPSG","6326"]],
> >>>>>   PRIMEM["Greenwich",0],
> >>>>>   UNIT["degree",0.0174532925199433],
> >>>>>   AUTHORITY["EPSG","4326"]]
> >>>>> Origin = (-96.965332031250000,32.464599609375000)
> >>>>> Pixel Size = (0.000001341104507,-0.000001341104507)
> >>>>> Image Structure Metadata:
> >>>>> INTERLEAVE=PIXEL
> >>>>> Corner Coordinates:
> >>>>> Upper Left  ( -96.9653320,  32.4645996) ( 96d57'55.20"W,
> >>>>> 32d27'52.56"N) Lower Left  ( -96.9653320,  32.4591064) (
> >>>>> 96d57'55.20"W, 32d27'32.78"N) Upper Right ( -96.9598389,
> >>>>> 32.4645996) ( 96d57'35.42"W, 32d27'52.56"N) Lower Right (
> >>>>> -96.9598389,  32.4591064) ( 96d57'35.42"W, 32d27'32.78"N) Center
> >>>>>  ( -96.9625854,  32.4618530) ( 96d57'45.31"W, 32d27'42.67"N) Band 1
> >>>>> Block=1024x1024 Type=Byte, ColorInterp=Red
> >>>>> Overviews: 2048x2048, 1024x1024, 512x512, 256x256
> >>>>> Overviews: arbitrary
> >>>>> Band 2 Block=1024x1024 Type=Byte, ColorInterp=Green
> >>>>> Band 3 Block=1024x1024 Type=Byte, ColorInterp=Blue
> >>>>> Joshua Jackson, PhD
> >>>>> <mailto:josh at nside.io <mailto:josh at nside.io>> <mailto:josh at nside.io
> >>>>> <mailto:josh at nside.io> <mailto:josh at nside.io
> >>>>> <mailto:josh at nside.io>>>   www.nSide.io <http://www.nside.io/>
> >>>>> <http://www.nside.io/ <http://www.nside.io/>> <http://www.nside.io/
> >>>>> <http://www.nside.io/>>> 4031 Parkway Dr, Suite B, Florence, AL
> >>>>> 35630
> >>>>> <http://www.linkedin.com/company/nside/>>>
> >>>>> <http://twitter.com/nSide__Out <http://twitter.com/nSide__Out>>>
http://www.spatialys.com
