[gdal-dev] GDAL slow to write GeoTIFF?
Even Rouault even.rouault at spatialys.com
Tue Apr 28 00:38:03 PDT 2015
Le mardi 28 avril 2015 08:25:57, jramm a écrit :
> By tiled do you mean split into N seperate TIFF files (in which case the
> answer is no), or can a single TIFF contain a tiling scheme?
Yes a TIFF can be tiled internally.
> If so, is this
> some option I need to pass to the driver when creating the output?
Yes TILED=YES. Cf http://www.gdal.org/frmt_gtiff.html
When tiling is enabled, the default tile size is 256x256. Which would match
the way you operate.
> http://osgeo-org.1560.x6.nabble.com/GDAL-slow-to-write-GeoTIFF-tp5203128p5
> 203202.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
