[gdal-dev] Formats that support RAT's?
Even Rouault even.rouault at spatialys.com
Tue Apr 28 13:58:16 PDT 2015
Le mardi 28 avril 2015 22:49:23, jramm a écrit :
> It seems GDAL will always let you create a Raster Attribute Table (in
> memory) but may fail when writing to disk depending on whether the format
> supports it?
A lot of format that relies on the PAM(Persistant Auxiliary Metadata)Dataset base class will serialize it in a .aux.xml file.
> I can't seem to find any information anywhere on what formats support
> RAT's? Is there a list I can refer to ??
From the result of "grep -r SetDefaultRAT frmts/ ", the answer is Idrisi, GeoRaster, KEA and HFA.
> http://osgeo-org.1560.x6.nabble.com/Formats-that-support-RAT-s-tp5203365.h
> tml Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
