[gdal-dev] OGR Field Types?
Stefan Keller sfkeller at gmail.com
Wed Apr 29 13:57:05 PDT 2015
Salut Even,
Merci!
2015-04-29 20:35 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Stefan
>> Questions:
>> 1. How is 'binary' encoded? E.g. when defining binary in a CSV file,
>> how is it encoded? Hex?
> There's no support in the CSV driver for binary data
>> 2. Can a field in a CSV input files have a IntegerList or a Binary?
> No. Well on writing, the IntegerList will be serialized as a string. But not
> recognized as IntegerList on reading
>> 3. What is the value delimiter in a field of type IntegerList,
>> Integer64List, RealList, StringList?
> The default serializatoin will be (number_of_elements:val1,val2,...,valn), but
> currently it is truncated to 80 chracters
>> 4. "Boolean, Int16, Float32" are mentioned as subtypes. Are there more
>> subtypes?
> Not currently. See https://trac.osgeo.org/gdal/wiki/rfc50_ogr_field_subtype
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
