[gdal-dev] Data type of DATE in SpatiaLite
Even Rouault even.rouault at spatialys.com
Thu Apr 30 15:52:49 PDT 2015
> > On reading, the SQLite driver will currently only accept data with stored
> > as text (speaking here about the content of each cell, not the declared
> > column type!) and will try to parse them as ISO-8601. If the values are
> > stored as floating point or integer values, it will report null. It
> > might be good to implement the rule at 1.2 Date and Time Datatype of
> > https://www.sqlite.org/datatype3.html to convert from Julian days or Unix
> > time.
I've added support to recognize floating point values in a Date/DateTime column
and convert from Julian fractional days to the expanded representation used by
GDAL. Only on reading. If you create/update records, they will be output as
ISO-8601 text.
> I agree and I think that on the Spatialite side it might be good to make
> the spatialite tools to declare the columns which are known to contain
> dates/times as DATE/DATETIME even those types do not really mean anything
> for SQLite and huge amounts of existing and future Spatialite databases
> hold dates and times in columns which are declared as TEXT, INTEGER,
> DOUBLE, or without a type at all.
> All in all, handling dates is the typeless SQLite in a reliable and
> interoperable way seems to be a bit complicated. I will think about writing
> a line or two into http://www.gdal.org/drv_sqlite.html about how GDAL plays
> with them once I understand it myself.
> -Jukka-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
