[gdal-dev] Regarding libkml driver
Rashad M mohammedrashadkm at gmail.com
Sun Aug 2 11:45:59 PDT 2015
On Sun, Aug 2, 2015 at 8:12 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Rashad,
> > Hello all,
> > We have been working on a new fork of libkml library on github. The
> primary
> > interest to detach from google/libkml was that various modification in
> the
> > library are fragmented in the github forks and nothing gets merged. There
> > is no activity or interest by original authors and all efforts to contact
> > them failed. You can find more details on why it forked here -
> > https://github.com/google/libkml/issues/4 . We had clearly explained
> this
> > also in the readme of the fork.  As the library is used in many open
> source
> > gis tools, we thought it might be worth to unify the efforts in one
> place.
> > Fix bugs, submit patches, publish new releases and so on.
> It would be great to have a lively libkml indeed, especially since the GDAL
> libkml driver depends on a unreleased version of the libkml code.
> Any plan/timeline to produce an "official" release of your fork ?
I had tagged 1.3.0-rc0 on github. https://github.com/libkml/libkml/releases
> > Would it be possible to have gdal kml driver to use this version?  If so
> > what will be the preferred way, submit a patch on trac will be
> > sufficient?.
> Does the GDAL libkml driver actually need changes ? Are there been API
> changes
No API changes. it make building and configuring libkml easier!
Correct me If I am wrong, I guess with a pkg-config would be easier to find
and configure libkml libs.
> > There are lot of enhancements and bug fixes in the fork. Most
> > of them are towards build system.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150802/eefe8f16/attachment.html>
