[gdal-dev] Additon to r29598
Even Rouault even.rouault at spatialys.com
Mon Aug 3 11:18:56 PDT 2015
On Monday 03 August 2015 16:20:44 Jukka Rahkonen wrote:
> Hi Even,
> By browsing what you have done with
> https://trac.osgeo.org/gdal/changeset/29598, should I understand that there
> is also a need for an additional edit in
> http://www.gdal.org/drv_elasticsearch.html, here:
> "However, the driver is limited in the geometry it handles: even if polygons
> are provided as input, they are stored as geo point and the "center" of the
> polygon is used as value of the point."
Hi Jukka,
thanks for the note. I've just fixed the doc. This is work in progress since
I'll add soon the read side of the driver.
Even
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
