[gdal-dev] Piping VRT to gdal_translate with /vsistdout
Luke lukepinnerau at gmail.com
Mon Aug 3 18:17:47 PDT 2015
Luke wrote
> Windows generates the following error (command was run in cmd.exe):
> ERROR 1: Parse error at EOF, not all elements have been closed,
> starting with Co
> The linux error is similar with "ColorInte" instead of "Co". Command was
> run in default bash shell using gnome terminal.
Ahhh... only the first 1024 characters are being read.  The difference in
the win->linux output is caused by \r\n and \n linebreaks respectively.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Piping-VRT-to-gdal-translate-with-vsistdout-tp5218386p5218388.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
