[gdal-dev] JasPer vs OpenJPEG performance
ewenger ewenger at ara.com
Fri Aug 7 04:59:30 PDT 2015
Jukka,
Thank you for your response.  I can't provide the image, but we're working
with 8-band MSI from Worldview-2 so the images are larger than 1024x1024.
Given your information, it sounds like compiler flags aren't going to help.
Do you think I'll see better performance on these tiles using either the
Kakadu or the ECW driver?
Regards,
--Eric
View this message in context: http://osgeo-org.1560.x6.nabble.com/JasPer-vs-OpenJPEG-performance-tp5218901p5218906.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
