[gdal-dev] Attempting to access an ArcGIS REST API through a WMS format minidriver
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Aug 10 09:55:40 PDT 2015
Hi Stefan,
The ArcGIS REST API was introduced in GDAL 2.0 (see
http://gdal.org/frmt_wms.html). What is you GDAL version?
Best regards,
     Dmitry
10.08.2015 19:02, Stefan Keller пишет:
> Hi Dmitry
> When testing your example I get "No mini-driver registered for 'AGS'.":
> >gdal_translate -of PNG ags.xml ags_test.png --config CPL_DEBUG ON
> ERROR 1: GDALWMS: No mini-driver registered for 'AGS'.
> GDALOpen failed - 1
> Do you know if this AGS mini-driver code is made publicly available
> i.e. being pushed to the GDAL source/trunk?
> Yours, Stefan
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150810/28e2302f/attachment.html>
