[gdal-dev] build error
Donovan Cameron sault.don at gmail.com
Tue Aug 18 11:47:07 PDT 2015
I made those changes but same error.
Tried once with,
#define _XOPEN_SOURCE
And a second time with,
#define _XOPEN_SOURCE 500
Donovan
On 18/08/15 10:30 AM, Even Rouault wrote:
> On Tuesday 18 August 2015 12:00:46 Vincent Schut wrote:
>> Hi,
>> this morning I wanted to refresh my gdal build, so I did an svn update (and
>> later a fresh svn checkout to be sure), but I get an error when make wants
>> to build gdalserver:
> This might be related to the following that is perhaps too restrictive
> #if defined(__STDC_VERSION__)
> #endif
> Could you try remonving the #if defined / #endif, so that #define _XOPEN_SOURCE
> is defined ?
> Perhaps you need #define _XOPEN_SOURCE 500
> Even
Kind regards,
Donovan
