[gdal-dev] build error
Donovan Cameron sault.don at gmail.com
Tue Aug 18 14:51:36 PDT 2015
I updated the ticket [1] too.
OS: Arch Linux 64-bit (Kernel 4.1.5), GCC 5.2.0
I put a paste of the netdb.h file up [2].
I'm not sure how to change those flags for gcc to -E, sorry, never done
that before.
On Arch Linux, I checked the contents of /etc/makepkg.conf where a lot
of compiler defaults are and didn't notice where I could place those.
Is there an environment variable I can set to help do that like CXXFLAGS
or CFLAGS?
[1] https://trac.osgeo.org/gdal/ticket/6073
[2] http://www.pastebin.ca/3112701
Donovan
On 18/08/15 02:06 PM, Even Rouault wrote:
> On Tuesday 18 August 2015 11:47:07 Donovan Cameron wrote:
>> I made those changes but same error.
>> Tried once with,
>> #define _XOPEN_SOURCE
>> And a second time with,
>> #define _XOPEN_SOURCE 500
> What is your config: OS + gcc ?
> I can't reproduce with Ubuntu 14.04 with gcc 4.8
> Could you intercept the gcc command line of gdalserver.c and replace the -c -o
> gdalserver.o by -E to have the preprocessor output ?
> Providing the /usr/include/netdb.h of your system might also give some clue,
> since it is in this file that getaddrinfo is defined.
>> Donovan
>> On 18/08/15 10:30 AM, Even Rouault wrote:
>>> On Tuesday 18 August 2015 12:00:46 Vincent Schut wrote:
>>>> Hi,
>>>> this morning I wanted to refresh my gdal build, so I did an svn update
>>>> (and
>>>> later a fresh svn checkout to be sure), but I get an error when make
>>>> wants
>>>> to build gdalserver:
>>> This might be related to the following that is perhaps too restrictive
>>> #if defined(__STDC_VERSION__)
>>> #endif
>>> Could you try remonving the #if defined / #endif, so that #define
>>> _XOPEN_SOURCE is defined ?
>>> Perhaps you need #define _XOPEN_SOURCE 500
>>> Even
Kind regards,
Donovan
