[gdal-dev] build error
Vincent Schut schut at sarvision.nl
Tue Aug 18 23:18:03 PDT 2015
On 08/18/2015 07:30 PM, Even Rouault wrote:
> On Tuesday 18 August 2015 12:00:46 Vincent Schut wrote:
>> Hi,
>> this morning I wanted to refresh my gdal build, so I did an svn update (and
>> later a fresh svn checkout to be sure), but I get an error when make wants
>> to build gdalserver:
> This might be related to the following that is perhaps too restrictive
> #if defined(__STDC_VERSION__)
> #define _XOPEN_SOURCE
> #endif
> Could you try remonving the #if defined / #endif, so that #define _XOPEN_SOURCE
> is defined ?
> Perhaps you need #define _XOPEN_SOURCE 500
> Even
I tried both (with and without "500"), but it makes no difference. Any other hints?
Best,
Vincent
