[gdal-dev] Fedora 20, fatal error: gdal/ogrsf_frmts.h: No such file or directory
Kyle Shannon kyle at pobox.com
Wed Aug 19 13:02:10 PDT 2015
mario,
On Wed, Aug 19, 2015 at 1:51 PM, mario60 <ml at mariochiari.net> wrote:
> Hi my first post. I am trying to install mysql-workbench from source on a 32
> bit Fedora 22 machine. I get the following error msg:
> In file included from
> /root/rpmbuild/BUILD/mysql-workbench-community-6.3.4-src/backend/wbpublic/grt/spatial_handler.cpp:20:0:
> /root/rpmbuild/BUILD/mysql-workbench-community-6.3.4-src/backend/wbpublic/grt/spatial_handler.h:23:30:
> fatal error: gdal/ogrsf_frmts.h: No such file or directory compilation
> terminated.
> Google does not help, and I am not sure what to look for.
> Could you help somehow?
> I appreciate
> mario
> ________________________________
> [root at localhost bin]# locate gdal
> /usr/bin/gdal_contour
> /usr/bin/gdal_grid
> /usr/bin/gdal_rasterize
> /usr/bin/gdal_translate
> /usr/bin/gdaladdo
> /usr/bin/gdalbuildvrt
> /usr/bin/gdaldem
> /usr/bin/gdalenhance
> /usr/bin/gdalinfo
> /usr/bin/gdallocationinfo
> /usr/bin/gdalmanage
> /usr/bin/gdalserver
> /usr/bin/gdalsrsinfo
> /usr/bin/gdaltindex
> /usr/bin/gdaltransform
> /usr/bin/gdalwarp
> /usr/lib/gdalplugins
> /usr/lib/libgdal.so.1
> /usr/lib/libgdal.so.1.18.2
> /usr/lib/ogdi/libgdal.so
> /usr/share/gdal
> /usr/share/aclocal/ax_lib_gdal.m4
> /usr/share/doc/gdal-libs
> /usr/share/doc/gdal-libs/COMMITERS
> /usr/share/doc/gdal-libs/LICENSE.TXT
> /usr/share/doc/gdal-libs/NEWS
> /usr/share/doc/gdal-libs/PROVENANCE.TXT
> /usr/share/doc/gdal-libs/PROVENANCE.TXT-fedora
> /usr/share/gdal/GDALLogoBW.svg
> /usr/share/gdal/GDALLogoColor.svg
> /usr/share/gdal/GDALLogoGS.svg
> /usr/share/gdal/compdcs.csv
> /usr/share/gdal/coordinate_axis.csv
> /usr/share/gdal/datum_shift.csv
> /usr/share/gdal/ellipsoid.csv
> /usr/share/gdal/epsg.wkt
> /usr/share/gdal/gcs.csv
> /usr/share/gdal/gcs.override.csv
> /usr/share/gdal/gdal_datum.csv
> /usr/share/gdal/gdalicon.png
> /usr/share/gdal/geoccs.csv
> /usr/share/gdal/gml_registry.xml
> /usr/share/gdal/gt_datum.csv
> /usr/share/gdal/gt_ellips.csv
> /usr/share/gdal/header.dxf
> /usr/share/gdal/inspire_cp_BasicPropertyUnit.gfs
> /usr/share/gdal/inspire_cp_CadastralBoundary.gfs
> /usr/share/gdal/inspire_cp_CadastralParcel.gfs
> /usr/share/gdal/inspire_cp_CadastralZoning.gfs
> /usr/share/gdal/nitf_spec.xml
> /usr/share/gdal/nitf_spec.xsd
> /usr/share/gdal/ogrvrt.xsd
> /usr/share/gdal/osmconf.ini
> /usr/share/gdal/ozi_datum.csv
> /usr/share/gdal/ozi_ellips.csv
> /usr/share/gdal/pci_datum.txt
> /usr/share/gdal/pci_ellips.txt
> /usr/share/gdal/pcs.csv
> /usr/share/gdal/pcs.override.csv
> /usr/share/gdal/prime_meridian.csv
> /usr/share/gdal/projop_wparm.csv
> /usr/share/gdal/ruian_vf_ob_v1.gfs
> /usr/share/gdal/ruian_vf_st_uvoh_v1.gfs
> /usr/share/gdal/ruian_vf_st_v1.gfs
> /usr/share/gdal/ruian_vf_v1.gfs
> /usr/share/gdal/s57agencies.csv
> /usr/share/gdal/s57attributes.csv
> /usr/share/gdal/s57attributes_aml.csv
> /usr/share/gdal/s57attributes_iw.csv
> /usr/share/gdal/s57expectedinput.csv
> /usr/share/gdal/s57objectclasses.csv
> /usr/share/gdal/s57objectclasses_aml.csv
> /usr/share/gdal/s57objectclasses_iw.csv
> /usr/share/gdal/seed_2d.dgn
> /usr/share/gdal/seed_3d.dgn
> /usr/share/gdal/stateplane.csv
> /usr/share/gdal/trailer.dxf
> /usr/share/gdal/unit_of_measure.csv
> /usr/share/gdal/vertcs.csv
> /usr/share/gdal/vertcs.override.csv
> /usr/share/man/man1/gdal_calc.1.gz
> /usr/share/man/man1/gdal_contour.1.gz
> /usr/share/man/man1/gdal_edit.1.gz
> /usr/share/man/man1/gdal_grid.1.gz
> /usr/share/man/man1/gdal_polygonize.1.gz
> /usr/share/man/man1/gdal_proximity.1.gz
> /usr/share/man/man1/gdal_rasterize.1.gz
> /usr/share/man/man1/gdal_translate.1.gz
> /usr/share/man/man1/gdal_utilities.1.gz
> /usr/share/man/man1/gdaladdo.1.gz
> /usr/share/man/man1/gdalbuildvrt.1.gz
> /usr/share/man/man1/gdalcompare.1.gz
> /usr/share/man/man1/gdaldem.1.gz
> /usr/share/man/man1/gdalinfo.1.gz
> /usr/share/man/man1/gdallocationinfo.1.gz
> /usr/share/man/man1/gdalmanage.1.gz
> /usr/share/man/man1/gdalmove.1.gz
> /usr/share/man/man1/gdalsrsinfo.1.gz
> /usr/share/man/man1/gdaltindex.1.gz
> /usr/share/man/man1/gdaltransform.1.gz
> /usr/share/man/man1/gdalwarp.1.gz
> View this message in context: Fedora 20, fatal error: gdal/ogrsf_frmts.h: No
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
You need the include files for gdal, I am not on a fedora machine, but
something like:
yum install gdal-devel
Will get the files needed to compile against.
Kyle
