[gdal-dev] gdal test failures
Priya Seth seth.osc at gmail.com
Wed Aug 19 20:38:58 PDT 2015
Hi All,
I have built  gdal from source on RHEL 7.1  and when I run the
autotest, the following HF2 driver tests are failing:
Script: gdrivers/hf2.py
  TEST: hf2_1 ... fail
    line 506: Did not get expected checksum on still-open file.
    Got 4716 instead of 4672.
  TEST: hf2_2 ... fail
    Got 4796 instead of 4672.
  TEST: hf2_4 ... fail
    Got 44135 instead of 49187.
I have tried with multiple versions/branches of gdal, but I am still
getting the same issues.
Any suggestions on why this might be happening?
Thanks!
Priya
