[gdal-dev] Fedora 22, fatal error: gdal/ogrsf_frmts.h: No such file or directory
Ari Jolma ari.jolma at gmail.com
Thu Aug 20 00:17:35 PDT 2015
mario,
I think you should ask this on a list where there are Fedora packagers.
Best regards,
Ari
On 20.08.2015 00:44, mario chiari wrote:
> Hi
> Il giorno mer, 19/08/2015 alle 22.37 +0200, mario chiari ha scritto:
>> Kyle
>> Yes,  now I see /usr/include/gdal/ogrsf_frmts.h
> Still, I am not able to built.
> I am not sure whether it is a issue about gdal, but maybe you know how
> to fix.
> Now the msg is:
>>>> make[2]: *** No rule to make target '/root/linux-res
> -6.3/gdal/lib/libgdal.so', needed by
> 'backend/wbpublic/libwbpublic.so.6.3.4'.  Stop.<<<
> what does it mean?
> I appreciate your help
> mario
> ps
> mysql-workbench.spec states:
> # Directory where iodbc and pyodbc binaries are located. Build both
> using the build_iodbc.sh script
> # If using distribution provided ODBC manager lib and pyodbc, then
> comment out this
> %define odbc_home        $HOME/linux-res-6.3/usr
> %define linuxres_home    $HOME/linux-res-6.3
> %define vsqlite_dir      $HOME/linux-res-6.3/vsqlite
> %define ctemplate_dir    $HOME/linux-res-6.3
> %define gdal_dir         $HOME/linux-res-6.3/gdal
> ps
> # locate libgdal.so
> /usr/lib/libgdal.so
> /usr/lib/libgdal.so.1
> /usr/lib/libgdal.so.1.18.2
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
