[gdal-dev] Fedora 22, fatal error: gdal/ogrsf_frmts.h: No such file or directory
mario chiari ml at mariochiari.net
Thu Aug 20 03:11:35 PDT 2015
Il giorno gio, 20/08/2015 alle 10.17 +0300, Ari Jolma ha scritto:
> mario,
> I think you should ask this on a list where there are Fedora
> packagers.
> Best regards,
> Ari
yes, I did.
It was suggested to "set gdal_dir enviroment variable to point to
proper location".
I am not sure how to do so, your advise is welcome.
thanks
mario
> On 20.08.2015 00:44, mario chiari wrote:
> > Hi
> > Il giorno mer, 19/08/2015 alle 22.37 +0200, mario chiari ha
> > scritto:
> > > Kyle
> > > Yes,  now I see /usr/include/gdal/ogrsf_frmts.h
> > Still, I am not able to built.
> > I am not sure whether it is a issue about gdal, but maybe you know
> > how
> > to fix.
> > Now the msg is:
> > > > > make[2]: *** No rule to make target '/root/linux-res
> > -6.3/gdal/lib/libgdal.so', needed by
> > 'backend/wbpublic/libwbpublic.so.6.3.4'.  Stop.<<<
> > what does it mean?
> > I appreciate your help
> > mario
> > ps
> > mysql-workbench.spec states:
> > # Directory where iodbc and pyodbc binaries are located. Build both
> > using the build_iodbc.sh script
> > # If using distribution provided ODBC manager lib and pyodbc, then
> > comment out this
> > %define odbc_home        $HOME/linux-res-6.3/usr
> > %define linuxres_home    $HOME/linux-res-6.3
> > %define vsqlite_dir      $HOME/linux-res-6.3/vsqlite
> > %define ctemplate_dir    $HOME/linux-res-6.3
> > %define gdal_dir         $HOME/linux-res-6.3/gdal
> > ps
> > # locate libgdal.so
> > /usr/lib/libgdal.so
> > /usr/lib/libgdal.so.1
> > /usr/lib/libgdal.so.1.18.2
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
