[gdal-dev] Fedora 22, fatal error: gdal/ogrsf_frmts.h: No such file or directory
Ari Jolma ari.jolma at gmail.com
Thu Aug 20 03:28:27 PDT 2015
On 20.08.2015 13:11, mario chiari wrote:
> Il giorno gio, 20/08/2015 alle 10.17 +0300, Ari Jolma ha scritto:
>> mario,
>> I think you should ask this on a list where there are Fedora
>> packagers.
>> Best regards,
>> Ari
> yes, I did.
> It was suggested to "set gdal_dir enviroment variable to point to
> proper location".
Hm. I'm guessing, you have
%define gdal_dir         $HOME/linux-res-6.3/gdal
and the error message is
-6.3/gdal/lib/libgdal.so', needed by
'backend/wbpublic/libwbpublic.so.6.3.4'.
So is the string "$HOME/linux-res-6.3/gdal" somehow not good since it is
broken in the message? Maybe it should not have "-" (at least three of
them)?
Ari
> I am not sure how to do so, your advise is welcome.
> thanks
> mario
>> On 20.08.2015 00:44, mario chiari wrote:
>>> Hi
>>> Il giorno mer, 19/08/2015 alle 22.37 +0200, mario chiari ha
>>> scritto:
>>>> Kyle
>>>> Yes,  now I see /usr/include/gdal/ogrsf_frmts.h
>>> Still, I am not able to built.
>>> I am not sure whether it is a issue about gdal, but maybe you know
>>> how
>>> to fix.
>>> Now the msg is:
>>>>>> make[2]: *** No rule to make target '/root/linux-res
>>> 'backend/wbpublic/libwbpublic.so.6.3.4'.  Stop.<<<
>>> what does it mean?
>>> I appreciate your help
>>> mario
>>> ps
>>> mysql-workbench.spec states:
>>> # Directory where iodbc and pyodbc binaries are located. Build both
>>> using the build_iodbc.sh script
>>> # If using distribution provided ODBC manager lib and pyodbc, then
>>> comment out this
>>> %define odbc_home        $HOME/linux-res-6.3/usr
>>> %define linuxres_home    $HOME/linux-res-6.3
>>> %define vsqlite_dir      $HOME/linux-res-6.3/vsqlite
>>> %define ctemplate_dir    $HOME/linux-res-6.3
>>> ps
>>> # locate libgdal.so
>>> /usr/lib/libgdal.so
>>> /usr/lib/libgdal.so.1
>>> /usr/lib/libgdal.so.1.18.2
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
