[gdal-dev] Fedora 22, fatal error: gdal/ogrsf_frmts.h: No such file or directory
mario60 ml at mariochiari.net
Thu Aug 20 04:28:29 PDT 2015
Il giorno gio, 20/08/2015 alle 03.22 -0700, Ari Jolma-2 [via OSGeo.org]
ha scritto:
> Hm. I'm guessing, you have
> %define gdal_dir         $HOME/linux-res-6.3/gdal
> and the error message is
> -6.3/gdal/lib/libgdal.so', needed by
> 'backend/wbpublic/libwbpublic.so.6.3.4'.
>> make[2]:
*** No rule to make target '/root/linux-res -6.3/gdal/lib/libgdal.so',
needed by 'backend/wbpublic/libwbpublic.so.6.3.4'.  Stop. <
m.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fedora-20-fatal-error-gdal-ogrsf-frmts-h-No-such-file-or-directory-tp5220370p5220423.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150820/8deed24f/attachment.html>
