[gdal-dev] Fedora 22, fatal error: gdal/ogrsf_frmts.h: No such file or directory
Ari Jolma ari.jolma at gmail.com
Thu Aug 20 05:17:05 PDT 2015
On 20.08.2015 14:28, mario60 wrote:
> Il giorno gio, 20/08/2015 alle 03.22 -0700, Ari Jolma-2 [via OSGeo.org]
> ha scritto:
> > Hm. I'm guessing, you have
> > %define gdal_dir         $HOME/linux-res-6.3/gdal
> > and the error message is
> > -6.3/gdal/lib/libgdal.so', needed by
> > 'backend/wbpublic/libwbpublic.so.6.3.4'.
> >> make[2]:
> *** No rule to make target '/root/linux-res -6.3/gdal/lib/libgdal.so',
> needed by 'backend/wbpublic/libwbpublic.so.6.3.4'.  Stop. <
ok, then, do you have the file /root/linux-res -6.3/gdal/lib/libgdal.so?
Ari
> m.
> View this message in context: Re: Fedora 22, fatal error:
> <http://osgeo-org.1560.x6.nabble.com/Fedora-20-fatal-error-gdal-ogrsf-frmts-h-No-such-file-or-directory-tp5220370p5220423.html>
> Sent from the GDAL - Dev mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html> at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150820/07988e05/attachment.html>
