[gdal-dev] Calculate histogram using pyramids instead of tiff
Even Rouault even.rouault at spatialys.com
Thu Aug 20 08:15:55 PDT 2015
On Thursday 20 August 2015 16:47:16 Andrea Peri wrote:
> Hi,
> I need to retrieve the histogram of a set of rasters.
> To do this I use the
> gdalinfo for every raster using the parameter "-hist".
> But this process take a long time because the rasters are huge and
> have 11 bands each of them.
> For my need the histogram informations should be sufficient at a
> middle level pyramid.
> So my question is if is possible with gdalinfo create the histogram
> from an intermediate pyramid level.
Not directly. At the API level, it is possible to require for approximate
histogram (and this will select a overview level that is close to 1 / 50 th of
the original raster size.
Otherwise a trick would be to extract the desired overview level with
gdal_translate -outsize (possibly as a VRT) and run gdalinfo -hist on it
> Thx for any hints.
http://www.spatialys.com
