[gdal-dev] RE : Gdal 2.0, supported raster/vector formats (RIK in particular)
TomasR monshi2+nn at gmail.com
Thu Aug 20 11:43:16 PDT 2015
Hi
This made me to try a bit more and found that gdal2 works with some
files but not with other files.
This small file
https://www.dropbox.com/s/5k86qh3g24wrb8r/ab-del.rik?dl=0
gdalinfo.exe can read and give data about.
This file
https://www.dropbox.com/s/a2dlnvgy5ckxu5b/testkarta.rik?dl=0
which is a bit bigger (25 MB) gdalinfo cannot read. The same for my app
in C#.
Yours
Tomas
Den 2015-08-20 kl. 13:29, skrev Even Rouault:
> RIK should be supported in 2.0 as well as in previous versions. could
> you share a file that no longer work?
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> -------- Message d'origine --------
> De : TomasR <monshi2+nn at gmail.com>
> Date :20/08/2015 11:09 (GMT+01:00)
> À : gdal-dev at lists.osgeo.org
> Cc :
> Objet : [gdal-dev] Gdal 2.0, supported raster/vector formats (RIK in
> particular)
