[gdal-dev] gdal test failures
Even Rouault even.rouault at spatialys.com
Fri Aug 21 13:30:35 PDT 2015
Le jeudi 20 août 2015 06:34:42, Priya Seth a écrit :
> I am getting the same issue when I run this command
> gdal_translate -of HF2 data/byte.tif data/byte.tif.tst
> Could this be some issue with translation from different formats to
> the HF2 format?
Hum is there a relationship in this report with
https://lists.osgeo.org/pipermail/gdal-dev/2015-August/042427.html ?
Which architecture (x86, amd64, ... ) are you running ? Which compiler version
Might be due to some subtle difference in floating point rounding.
> Thanks!
> On Thu, Aug 20, 2015 at 9:08 AM, Priya Seth <seth.osc at gmail.com> wrote:
> > Hi All,
> > I have built  gdal from source on RHEL 7.1  and when I run the
> > autotest, the following HF2 driver tests are failing:
> > Script: gdrivers/hf2.py
> >   TEST: hf2_1 ... fail
> >     line 506: Did not get expected checksum on still-open file.
> >     Got 4716 instead of 4672.
> >   TEST: hf2_2 ... fail
> >     Got 4796 instead of 4672.
> >   TEST: hf2_4 ... fail
> >     Got 44135 instead of 49187.
> > I have tried with multiple versions/branches of gdal, but I am still
> > getting the same issues.
> > Any suggestions on why this might be happening?
> > Thanks!
> > Priya
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
