[gdal-dev] The vrt datasource from gdalbuildvrt report a wrong block of 128x128
Andrea Peri aperi2007 at gmail.com
Sat Aug 22 22:43:03 PDT 2015
I have a tiff tiled with tile size 1024 x 1024.
When I try to build a vrt-datasource on it using the gdalbuildvrt.
I see the result vrt file report a
block of 128x128 instead of 1024x1024.
I dont know if this is correct by the gdalbuildvrt oint of view
Also I like to know if is preferrably to correct manually  the vrt
result to report the right value 1024
or is also acceptable to maintain the 128 size reported for the right
work of the gdal utilities in the vrt file.
Thx,
Andrea Peri
qwerty àèìòù
