[gdal-dev] Issue with gdalchksum on Fedora 21 ppc64le?
Even Rouault even.rouault at spatialys.com
Tue Aug 25 06:17:01 PDT 2015
> From a quick look it doesn't appear to be the same issue as for HF2. And
> I've actually recompiled GDAL with -fsigned-char on x86_64 to simulate
> ppc64le behaviour regarding char,
I was obviously not well awoken this morning, since I should rather have used
-funsigned-char to make char behave like unsigned char. Anyway after trying
this switch, the conclusion is the same...
http://www.spatialys.com
