[gdal-dev] Question
Giorgio Ghiggini gghiggini at gec-it.com
Wed Aug 26 05:34:11 PDT 2015
Hello,
I am trying to use GDAL ogr2ogr.exe but I am having problems with
osmconf.ini file configuration.
I tried using different binaries for Windows (QGIS, Gisinternals, OSGeo4W
and MapServer) but I am not able to get all tags from a PBF or OSM file.
Probably I am not able to configure properly the ini file (here attached),
but all changes I do, have no impact on the result.
Here is the command line I use:
ogr2ogr -f "ESRI Shapefile" -skipfailures -sql "select * from points where
other_tags LIKE '%peak%'" F:\GEC\Sources\OSM\Italy
F:\GEC\Sources\OSM\italy-latest.osm.pbf
With this configuration I would like to export the "ele" attribute for
"natural=peak", but I am not able to get it in my shapefile.
Any suggestion is very appreciated.
Best regards,
Giorgio
Giorgio Ghiggini
GEC di Ghiggini Giorgio
Via Monte Matanna 1/C
55049 Viareggio (LU)
Italy
P.Iva: 01381570116
cell.: +39 331 141 9315
email: gghiggini at gec-it.com
www.gec-it.com
 <http://www.globalterramaps.com/> www.globalterramaps.com
www.globalaquamaps.com <http://www.globalaquamaps.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150826/fed9d87e/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150826/fed9d87e/attachment.obj>
