[gdal-dev] Issue with gdalchksum on Fedora 21 ppc64le?
Gawade P gawade.oefp at gmail.com
Thu Aug 27 21:44:28 PDT 2015
Hi Even,
Please find my response below:
>Interesting, I wouldn't have thought this to change the result of the
>rounding, but who knows... Could you compare the color tables to check that
>the differences are just within a +/- 1 amplitude ?
Yes. The map does not change for +ve slope values. For -ve slope
values there is a consistent deviation of -1 through all values
Attaching a sample data set for your reference.
>Yes, once we get same results on both platforms, adjusting the expected
>checksums of nwt_grd.py / nwt_grc.py scripts might be needed.
Confirmed that we are getting the same results on both platforms.
Looks like no changes are needed in nwt_grc.py. It still passes and
checksum value is still same.
Updated nwt_grd.py as follows, and it passes:
    tst2 = gdaltest.GDALTest( 'NWT_GRD', 'nwt_grd.grd', 2, 33690 )
    status2 = tst2.testOpen()
    tst3 = gdaltest.GDALTest( 'NWT_GRD', 'nwt_grd.grd', 3, 20365 )
    status3 = tst3.testOpen()
Please let me know if any more verification is required. Thanks!
On Thu, Aug 27, 2015 at 4:00 PM, Even Rouault
<even.rouault at spatialys.com> wrote:
> Le jeudi 27 août 2015 12:23:07, Gawade P a écrit :
>> Thanks, Even.I have tried this change on ppc and there were some
>> differences in the map values resulting in a small deviation in the
>> final checksum value compared to the current output on x86
>> The output on ppc with this change is:
>> bash-4.2# gdalchksum.py nwt_grd.grd
>> 28093
>> 33690
>> 20365
>> 25856
>> The expected values for band 2 and 3 are :
>> 33626
>> 20260
> Thinking more, a cause for a difference of rounding should happen with negative
> values, since casting truncates to the upper integer in case of negative
> value. I'd think my proposed formula to be (slightly) more accurate in case of
> negative slope, since it will only cast positive values.
>> I have not tried this change on x86, will try and let you know. Could
>> there be any implications of these changed values elsewhere in the
>> code (Assuming that they will change on x86 as well)? I believe some
>> test cases might fail as well...
>> On Thu, Aug 27, 2015 at 3:10 PM, Even Rouault
>> > Le jeudi 27 août 2015 06:20:41, Gawade P a écrit :
>> >> Good Morning, Even.
>> >> I debugged this more, focusing, as you suggested, on the  computation
>> >> of the colormap and looks like the difference in the value of the
>> >> checksum is due to the difference in calculation of the color map
>> >> values for negative slopes. The following lines of code in
>> >> frmts/northwood/northwood.cpp, createIP() function are exhibiting
>> >> different behavior on intel and ppc:
>> >>      for( i = wm + 1; i < index; i++)
>> >>         map[i].r = map[wm].r + (unsigned char)(((i - wm) * rslope) +
>> >>         0.5); map[i].g = map[wm].g + (unsigned char)(((i - wm) *
>> >>         gslope) + 0.5); map[i].b = map[wm].b + (unsigned char)(((i -
>> >>         wm) * bslope) + 0.5);
>> >> primarily, because of the (unsigned char) casting of the second
>> >> operand. Looks like the behavior could be undefined if the float value
>> >> resulting from the computation of the expression (((i - wm) * bslope)
>> >> + 0.5) is negative, as would be the case for negative slope.
>> >> For ppc, the expression  (unsigned char)(((i - wm) * bslope) + 0.5) is
>> >> evaluating to zero, whenever the result of (((i - wm) * bslope) + 0.5)
>> >> is -ve i.e. for -ve slope
>> > Interesting. It is likely that the result of the cast (unsigned
>> > char)negative_floating_point_value is undefined by the C standard and
>> > there might be differences in behaviour according to the CPU here (seems
>> > to be confirmed by
>> > http://stackoverflow.com/questions/2490600/iphone-floats-cast-to-
>> > unsigned-ints-get-set-to-0-if-they-are-negative)
>> > I think the following should be portable:
>> > map[i].r = (unsigned char)(map[wm].r + (i - wm) * rslope + 0.5);
>> > map[i].g = (unsigned char)(map[wm].g + (i - wm) * gslope + 0.5);
>> > map[i].b = (unsigned char)(map[wm].b + (i - wm) * bslope + 0.5);
>> > Could you confirm ?
>> > W might want to explictly clamp to [0,255] before casting, but according
>> > to the formulas of the slope, I'm confident the result should already be
>> > in [0,255.X] range.
>> > Even
>> > Spatialys - Geospatial professional services
>> > http://www.spatialys.com
Type: application/vnd.ms-excel
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150828/f45c2570/attachment-0001.xls>
