[gdal-dev] NSIF with GDAL
Even Rouault even.rouault at spatialys.com
Mon Aug 31 02:13:15 PDT 2015
Le lundi 31 août 2015 10:34:25, Bar Ori a écrit :
> Hello,
> I have a purpose to create a file in format of NSIF.
> As far as understood, I need to use the NITF driver and set the metadata
> which is relevant to NSIF. I tried to work with GDAL to make it, but
> noticed that the metadata is saved on a "aux.xml" file. When I remove this
> file or when set the GDAL_PAM_ENABLED as NO, so I lose all metadata I set
> (return to default or deleted). My goal is to create one file (.nsf)
> containing all the relevant metadata. My question is whether it is
> possible to create one file as I want. In case that yes, how to do it?
> P.S. I am using GDAL in C#
Ori,
Quoting http://gdal.org/frmt_nitf.html:
 Creation Options:
    * Most file header, imagery header metadata and security fields can be set
with appropriate creation options (although they are reported as metadata
item, but must not be set as metadata). For instance setting "FTITLE=Image of
abandoned missle silo south west of Karsk" in the creation option list would
result in setting of the FTITLE field in the NITF file header. Use the official
field names from the NITF specification document; do not put the "NITF_" prefix
that is reported when asking the metadata list.
The full list of creation options is given by:
gdalinfo --format nitf
In C#, that would be something like
string[] options = new string [] {"FTITLE=mytitle"};
Dataset out_ds = drv.CreateCopy("out.ntf", src_ds, 0, options, null, null);
or
Dataset out_ds = drv.Create("out.ntf", width, height, bands,
                                             DataType.GDT_Byte, options);
Even
> Hope for a for a quick response.
> Thanks,
> Ori Bar | Software Developer
> T +972-9-8898900 | M +972-504-734296
> @ Ori.Bar at Elbitsystems.com<mailto:Ori.Bar at Elbitsystems.com>
> [Description: Description: Logo]
> The information in this e-mail transmission contains proprietary and
> business sensitive information.  Unauthorized interception of this e-mail
> may constitute a violation of law. If you are not the intended recipient,
> you are hereby notified that any review, dissemination, distribution or
> duplication of this communication is strictly prohibited. You are also
> asked to contact the sender by reply email and immediately destroy all
> copies of the original message.
http://www.spatialys.com
