[gdal-dev] Extending nitf_spec.xml
Brad Hards bradh at frogmouth.net
Tue Dec 8 02:26:28 PST 2015
On Tue, 8 Dec 2015 11:20:47 AM Even Rouault wrote:
> > I use the GDAL nitf_spec.xml file
> > (https://trac.osgeo.org/gdal/browser/trunk/gdal/data/nitf_spec.xml) in an
> > open source project (Java library:
> > https://github.com/codice/imaging-nitf). I'm trying to figure out how to
> > extend my library to support writing as well as reading. I try to keep the
> > file the same (better for everyone, really).
> I see you've added a few new TRE defs in your version. Any plan proposing
> them for GDAL too ?
I thought I already had, but clearly not. Will fix ASAP.
The SENSRB stuff is really complex, and I did a lot of unit tests to check that
each optional element works, so I should get you that. Not sure how important
MENSRB is, but I'll put that in as well.
Brad
