[gdal-dev] Changing pixel values of GDAL VRT
Even Rouault even.rouault at spatialys.com
Tue Dec 15 09:14:15 PST 2015
Le mardi 15 décembre 2015 17:23:44, cl a écrit :
> Is it possible to manipulate the pixel values of a GDAL VRT and, if so,
> how? The original data must remain unchanged.
> I have a dataset which might be a bit rotated so that there are no data
> values on the edges. I use region growing to find that parts on the edge to
> not touch no data values in the actual area. I want to interpolate in the
> actual area in a next step. Sometimes I might have e.g. a very large
> dataset or ASCII data which can not be overwritten.
So basically you'd want a http://gdal.org/nearblack.html that would work on
the fly ?
> http://osgeo-org.1560.x6.nabble.com/Changing-pixel-values-of-GDAL-VRT-tp52
> 41432.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
