[gdal-dev] GDAL built with MinGW dll size
Even Rouault even.rouault at spatialys.com
Sun Dec 20 04:15:05 PST 2015
Le dimanche 20 décembre 2015 12:26:05, Predator a écrit :
> Hi,
> I have managed to built gdal with MinGW 4.8.1 and MSYS. The output
> libgdal-1.dll file weighs 49MB. It's a lot. The same library available to
> download from gisinternals built with MVSC weighs 9-10MB.
> So my question is: Have I done something wrong, or it is normal for MinGW?
> Can I somehow reduce dll size?
Are you sure it is an optimized build (with -O2) without debugging symbol (no
-g) ?
> http://osgeo-org.1560.x6.nabble.com/GDAL-built-with-MinGW-dll-size-tp52421
> 65.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
