[gdal-dev] GDAL built with MinGW dll size
Ko Nagase nagase at georepublic.co.jp
Mon Dec 21 03:56:47 PST 2015
Hi Predator,
I have no experience about gdal MinGW build,
but normally, I execute "strip *.dll" after "make install".
https://github.com/sanak/pgrouting4w/blob/master4w/BUILD.mingw#L142
Could you try to do that ?
Regards,
Ko
2015-12-21 18:21 GMT+09:00 Predator <Predator89 at interia.eu>:
> Thanks for replies.
> Did you use standard commands (./configure, make, make install), or have you
> changed something?
> What about makefile or config file? Did you apply any changes to them?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-built-with-MinGW-dll-size-tp5242165p5242253.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ko Nagase (長瀬 興)
Georepublic Japan
mail: nagase at georepublic.co.jp
web: http://georepublic.co.jp
