[gdal-dev] Writing Coded Domain Values from GDAL
Gane R gane.prog at gmail.com
Tue Dec 22 03:46:29 PST 2015
I tried to read the coded domain values from GDAL, I used special sql
requests from GDAL as described in FileGeoDB driver. I got the values in
the XML format.
Is it possible to write coded domain values from GDAL using special sql
request.
I saw that it was possible from ESRI filegeodb API, can this be done from
GDAL itself.
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151222/b8dd436f/attachment-0001.html>
