[gdal-dev] OpenJPEG
Aaron Boxer boxerab at gmail.com
Tue Dec 22 07:13:35 PST 2015
On Tue, Dec 22, 2015 at 9:01 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 22 décembre 2015 14:38:30, Aaron Boxer a écrit :
> > On Tue, Dec 22, 2015 at 4:34 AM, Jukka Rahkonen <
> > jukka.rahkonen at maanmittauslaitos.fi> wrote:
> > > Aaron Boxer <boxerab <at> gmail.com> writes:
> > > > This feature would be quite involved: one would have to gather all of
> > > > the
> > > layers for
> > > > all of the code blocks in all of the precincts overlapping that
> > > sub-tile,plus the immediately surrounding precincts, run the inverse
> > > entropy
> > > coder to get the wavelet coefficients, and then do an inverse wavelet
> > > transform,with this incomplete set of coefficients.
> > > I do not claim that I understand GIS but I have a feeling that
> precincts
> > > are
> > > designed for a fast ROI access. From
> > > http://www2.engr.arizona.edu/~bilgin/publications/SPIE2004_2.pdf
> > > "A precinct is a collection of code-blocks representing some finite
> > > spatial extent at some resolution."
> > > Probably gathering the surrounding precincts is unnecessary. Author of
> > > Kakadu seems to dislike tiles and it is no wonder that with Kakadu
> > > precincts
> > > perform well even with archived documents
> > > http://www.digitizationguidelines.gov/still-image/documents/Martin.pdf
> > Thanks, that paper was an interesting discussion of optimal encoding
> > settings in the archive world.
> > What are typical j2k encoding settings in geo-spatial use case ?
> That must depend vastly on the producer.
> A few examples:
> You can download Sentinel-2 products at :
> https://scihub.copernicus.eu/s2/#/home
> up to 10980x10980 images, 12 bit, with 2048x2048 tiles
> Pleidas products :
> http://www.geo-airbusds.com/en/23-sample-imagery
> Bigger dimension that S-2. Also 12 bit, with 2048x2048 tiles
> There are likely sources that are single tiled.
Thanks. These sites will be very useful.
Is it standard to add TLM and PLM markers?  Because these make fast random
access
possible.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151222/0e5026fd/attachment.html>
