[gdal-dev] Can not connect to MSSQL database on Azure
Tamas Szekeres szekerest at gmail.com
Mon Dec 28 13:18:31 PST 2015
Hi Paul,
I don't think we are hard coding trusted_connection in the MSSQL connection
strings. The UID and PWD is also accepted in the ODBC connection strings
according to: https://msdn.microsoft.com/en-us/library/ms130822.aspx
Best regards,
Tamas
2015-12-28 22:05 GMT+01:00 Paul Meems <bontepaarden at gmail.com>:
> I'm trying to connect to a MSSQL database on Azure using a SQL Server user
> account but I get this from GDAL (v2): Unable to initialize connection to
> the server for MSSQL:server=***;database=***;user=*** ;password=*** [SQL
> Server]Login failed. The login is from an untrusted domain and cannot be
> used with Windows authentication.
> A co-worker looked at the code of the MSSQL driver and noticed you
> are using the ODBC drivers, but are hard coding the trusted_connection
> parameter to be yes.
> Is this by design?
> Should I file a issue report?
> Thanks,
> Paul
> *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
> Download the latest MapWinGIS mapping engine.
> <https://mapwingis.codeplex.com/releases>
> Download the latest MapWindow 5 open source desktop application.
> <https://mapwindow5.codeplex.com/releases>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20151228/4822c4af/attachment.html>
