[gdal-dev] Bands supported
Even Rouault even.rouault at spatialys.com
Sun Feb 1 07:44:39 PST 2015
Le dimanche 01 février 2015 16:38:36, yuta sato a écrit :
> What are the maximum number of bands supported by gdal buildvrt with
> separate parameter?
There's no hard coded limit. In practice, the limit will be the amount of
memory available and size of the VRT. The opening time of the VRT will also
slow if it gets too big. But I believe with thousands of input files that
should still be OK.
Even
http://www.spatialys.com
