[gdal-dev] Use gdal2tiles to generate XYZ cache
Petr Pridal - Klokan Technologies GmbH petr.pridal at klokantech.com
Mon Feb 2 17:26:32 PST 2015
Hi there,
MapTiler generates xyz by default, and back-compatible tms with -tms on the
command line or in the GUI with a switcher in the Advanced options dialog.
Regards,
Petr
On Tue, Feb 3, 2015 at 2:20 AM, Klokan Petr Pridal <klokan at klokan.cz> wrote:
> Hi there,
> maptiler generates xyz by default, and back-compatible tms with -tms on
> the command line or in the GUI with switcher in advanced options.
> Regards,
> Petr
> On Tue, Feb 3, 2015 at 1:02 AM, Jorge Arévalo <jorge at cartodb.com> wrote:
>>  Hello,
>> Looks like gdal2tiles is only able to generate TMS caches (OGC standard).
>> Or is there any combination of parameters to generate a tile cache in XYZ
>> format? (top-left standard). I've tried with all the profiles (-p option),
>> but not getting the desired results... Any hints?
>> Best regards,
>> Jorge Arévalo
>> CartoDB
>> http://cartodb.com/
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://blog.klokan.cz/
> http://www.maptiler.org/
> http://www.oldmapsonline.org/
Petr Pridal, Ph.D.
(managing director)
Hofnerstrasse 96, 6314 Unterageri, Switzerland
Tel: +41 (0)41 511 26 12
Email: info at klokantech.com
Web: http://www.klokantech.com/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150203/9efab1e5/attachment-0001.html>
