[gdal-dev] Quick question about gdal2tiles
Jorge Arévalo jorge at cartodb.com
Thu Feb 5 09:59:19 PST 2015
Thanks for the tips, Klokan. Really useful. We already have a maptiler
license, and we use it, but we can't use that tool this time.
Best regards,
Jorge
> Klokan Petr Pridal <mailto:klokan at klokan.cz>
> February 3, 2015 at 2:18 AM
> Hi Jorge,
> rendering of your sample file down to zoomlevel 19 would generate over
> 2 billion tiles - probably tens of terabytes of data. I guess it is
> not what you want to do... Typically the overzooming is done on client
> side in a JavaScript viewer or on the tileserver hosting.
> The tiling utilities suggests you the native zoom level automatically
> - based on the raster resolution of the input.
> In case you want to render large datasets composed of multiple files
> efficiently I would recommend to try our MapTiler Pro command line
> utility.
> It is significantly faster then GDAL2Tiles and produces optimised and
> correct tiles, while handling merging of multiple files, solving
> issues with dateline crossing, reprojection and merging of data in
> different srs, direct output to MBTiles, OGC WMTS compatible export,
> and many more features.
> The usage on command line is quite easy:
> $ maptiler -o merged_output_dir input1.tif input2.tif input3.tif
> Input files can be in the original srs - every extra reprojection
> degrades visual quality of the output.
> Merging with VRT is not recommend - it slow down the tile rendering,
> as there are artificial blocks introduced - it is better for
> performance to pass the original files directly.
> MapTiler is a complete C/C++ reimplementation of my GDAL2Tiles
> utility. There are several significant improvements in the merging and
> internal tiling process including multi-thread CPU parallelization and
> automatic file size optimisation (PNG color quantization and JPEG tweaks).
> Installation is possible with the .deb or .rpm packages or binaries
> for Mac OS X or Windows or Docker.
> The small file, like your sample mentioned above, can be rendered
> directly with the MapTiler Free in the graphical user interface which
> is available for download at: http://www.maptiler.com/download/
> If you drop us an email we send you also the Pro version with command
> line for your free testing.
> Best regards,
> Petr Pridal, PhD
> Klokan Technologies GmbH
> http://blog.klokan.cz/
> http://www.maptiler.org/
> http://www.oldmapsonline.org/
> Jorge Arévalo <mailto:jorge at cartodb.com>
> January 29, 2015 at 1:13 AM
> El jueves, 29 de enero de 2015, Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> escribió:
>     Le jeudi 29 janvier 2015 00:05:32, Jorge Arévalo a écrit :
>     > > Even Rouault <mailto:even.rouault at spatialys.com <javascript:;>>
>     > > January 28, 2015 at 9:28 PM
>     > > Le mercredi 28 janvier 2015 20:17:08, Jorge Arévalo a écrit :
>     > >> Hi,
>     > >> I'm working with a patched version of gdal2tiles, which makes
>     use of
>     > >> parallelization:
>     http://gis.stackexchange.com/questions/7743/performance-of-google-map-ti
>     > >> le- creation-processes/74446#74446
>     > >> I want to create a complete TMS cache from raster imagery. No
>     > >> assumptions about SRS of data type for input data.
>     > >> I want the tiling process to be as fast as possible
>     (gdal2tiles is
>     > >> really heavy process), do you have any recomendations about
>     the data or
>     > >> the parameters used?
>     > >> Right now, I'm doing this
>     > >> Step 1: build vrt from input images
>     > >> gdal_vrtmerge.py -o merged.vrt<list of input tif files>
>     > >> Step 2: build tiles from vrt file
>     > >> gdal2tiles.py -r cubic -s epsg:XXXX -z 0-19 -w all merged.vrt
>     tms_dir
>     > >> Even with parallelization, process still feels really slow.
>     Would it be
>     > >> faster if, for example, I convert all my input files to
>     epsg:3857? Or if
>     > >> I scale them to 8-bit? Or if I use near resampling method
>     instead of
>     > >> cubic? (I'm using cubic because I'm working with continuous data:
>     > >> satellite images, am I doing it right?).
>     > >  From a quick look at the source, it seems that there's an
>     optimization
>     > >  if the
>     > > input SRS == output SRS that avoids going through the warped
>     VRT path.
>     > > That said, we definitely need one or several maintainers for
>     gdal2tiles.
>     > > There are quite a faw patches floating around in Trac that
>     would need
>     > > someone to review, test, fix, apply them, as well as writing
>     tests (no
>     > > autotest for gdal2tiles yet), etc...
>     > Ok. But the applications is taking hours to generate a complete tile
>     > cache (zoom levels 0-19) for a 3MB tiff file, in epsg:3857. A 4
>     cores
>     > machine with 8GB of RAM. The file is this one
>     https://dl.dropboxusercontent.com/u/6599273/gis_data/katrina-3857.tif
>     > Taking so much time for a 3MB file sounds ridiculous. I'm
>     probably doing
>     > something wrong. This is the line
>     > gdal2tiles.py  -s epsg:3857 -z 0-19 -r cubic katrina-3857.tif
>     tiles_dir
>     > Do you see something wrong in this approach?
>     The performance seems to be deeply impacted by "-r cubic", but
>     even without
>     it, it still sucks. The reason is the zoom level 19. Your dataset
>     has a
>     resolution of 3469 m. zoom 19 corresponds to a resolution of ~ 0.3
>     m. So you
>     basically try to generate a TMS that is rougly 12000 x 12000
>     larger than your
>     source dataset...
> Wow, thanks for the enlightment. So, with that resolution, I could
> easily create TMS cache until levels 5-6, according to this
> https://msdn.microsoft.com/en-us/library/aa940990.aspx
> If I'd want higher zoom levels... That could mean
> high processing cost. Worse if cúbic resampling method is used.
> Conclussion: better guessing the highest zoom level for
> that resolution using the table on the previous link, and building the
> TMS cache with that constraint in mind.
> Thanks again, Even!
>     > Anyway, if this is a problem of gdal2tiles and it needs fine
>     tunning or
>     > maintenance, we could talk. I don't know if there's any other
>     method to
>     > generate a complete TMS cache using GDAL.
>     > >> Any other tips?
>     > >> Many thanks in advance
>     > >> Best regards
>     Spatialys - Geospatial professional services
>     http://www.spatialys.com
> Jorge Arévalo
> http://cartodb.com/
> Skype ID: jorgecartodb
> Even Rouault <mailto:even.rouault at spatialys.com>
> January 29, 2015 at 12:27 AM
>>> Even Rouault<mailto:even.rouault at spatialys.com>
>>>> Hi,
>>>> I'm working with a patched version of gdal2tiles, which makes use of
>>>> parallelization:
>>>> I want the tiling process to be as fast as possible (gdal2tiles is
>>>> really heavy process), do you have any recomendations about the data or
>>>> gdal2tiles.py -r cubic -s epsg:XXXX -z 0-19 -w all merged.vrt tms_dir
>>>> Even with parallelization, process still feels really slow. Would it be
>>>> faster if, for example, I convert all my input files to epsg:3857? Or if
>>>> I scale them to 8-bit? Or if I use near resampling method instead of
>>>    From a quick look at the source, it seems that there's an optimization
>>>   if the
>>> input SRS == output SRS that avoids going through the warped VRT path.
>>> That said, we definitely need one or several maintainers for gdal2tiles.
>>> There are quite a faw patches floating around in Trac that would need
>>> someone to review, test, fix, apply them, as well as writing tests (no
>> cache (zoom levels 0-19) for a 3MB tiff file, in epsg:3857. A 4 cores
>> Taking so much time for a 3MB file sounds ridiculous. I'm probably doing
>> gdal2tiles.py  -s epsg:3857 -z 0-19 -r cubic katrina-3857.tif tiles_dir
> The performance seems to be deeply impacted by "-r cubic", but even without
> it, it still sucks. The reason is the zoom level 19. Your dataset has a
> resolution of 3469 m. zoom 19 corresponds to a resolution of ~ 0.3 m. So you
> basically try to generate a TMS that is rougly 12000 x 12000 larger than your
> source dataset...
>> Anyway, if this is a problem of gdal2tiles and it needs fine tunning or
>> maintenance, we could talk. I don't know if there's any other method to
>>>> Any other tips?
>>>> Best regards
> January 29, 2015 at 12:05 AM
>>> Hi,
>>> parallelization:
>>> http://gis.stackexchange.com/questions/7743/performance-of-google-map-tile-
>> > From a quick look at the source, it seems that there's an optimization if the
>> That said, we definitely need one or several maintainers for gdal2tiles. There
>> are quite a faw patches floating around in Trac that would need someone to
>> review, test, fix, apply them, as well as writing tests (no autotest for
> doing something wrong. This is the line
> or maintenance, we could talk. I don't know if there's any other
> method to generate a complete TMS cache using GDAL.
>>> Any other tips?
>>> Best regards
>> Hi,
>> parallelization:
>> Any other tips?
>> Best regards
Sent with Postbox <http://www.getpostbox.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/004d6339/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/004d6339/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/004d6339/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/004d6339/attachment-0005.jpg>
