[gdal-dev] Are those 2 things possible using gdal2tiles?
Jorge Arévalo jorge at cartodb.com
Thu Feb 5 10:31:00 PST 2015
> Jorge Arévalo <mailto:jorge at cartodb.com>
> February 5, 2015 at 7:15 PM
> - Generate JPEG tiles instead of PNG. Tried just replacing the
> driver's name (PNG) with JPEG. Didn't work. Base tiles are generated,
> but overview tiles are not. Getting this error instead: ERROR 1:
> Buffer too small
> - Apply a color to nodata value of generated tiles. Tried passing -a
> "200,0,0" to gdal2tiles, but it was ignored.
> Log file, with GDAL_DEBUG=On, where you can see the first problem
> (buffer too small):
> https://dl.dropboxusercontent.com/u/6599273/errors/gdal/gdal2tiles_error.log
> Modified version of gdal2tiles, to generate xyz caches instead of tms
> ones:
> https://dl.dropboxusercontent.com/u/6599273/errors/gdal/gdal2tiles_modified.py
> tif tile for testing (same error with other ones):
> https://dl.dropboxusercontent.com/u/6599273/gis_data/katrina.tif
> Many thanks!
Hint: The problem is in swig/python/extensions/gdal_wrap.cpp, method
GDALDatasetShadow_WriteRaster, because Buf len = 196608, min buffer size
= 262144. So, I know the reason, but still doesn't know how to fix this
Jorge Arévalo
CartoDB
http://cartodb.com/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/e3dabf5c/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150205/e3dabf5c/attachment-0001.jpg>
