[gdal-dev] GDAL 1.11.0 and Cosmo-skymed L1A imagery
vf victor.fomin.1 at gmail.com
Fri Feb 6 04:52:15 PST 2015
Well, you are right, I do not find neither the code that I pasted before in
the .diff.
Probably, it should be a local 'patch' used with gdal 1.10.1 to read
correctly CSK imagery. Sorry.
I will look what can be done with this code and gdal 1.11.0 version and put
the patch in the tracker.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-1-11-0-and-Cosmo-skymed-L1A-imagery-tp5185900p5185963.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
