[gdal-dev] Hidden regression in GDAL 1.11.0 - gdal_rasterize with postgis silently fails to render many polygons.
Even Rouault even.rouault at spatialys.com
Mon Feb 9 09:01:21 PST 2015
Graeme,
I tried to reproduce your issue as close as possible but couldn't replicate the bug.
I create a postgis layer with 360x180 polygons with the following Python script
from osgeo import ogr
from osgeo import osr
ds = ogr.Open('pg:dbname=autotest')
srs = osr.SpatialReference()
srs.ImportFromEPSG(4326)
lyr = ds.CreateLayer('world_diamonds', geom_type = ogr.wkbPolygon, srs = srs, options = ['OVERWRITE=YES'])
lyr.StartTransaction()
for y in range(180):
    for x in range(360):
        f = ogr.Feature(lyr.GetLayerDefn())
        x0 = x - 180 + 0.5
        y0 = 90 - y - 1
        f.SetGeometry(ogr.CreateGeometryFromWkt('POLYGON((%f %f,%f %f,%f %f,%f %f,%f %f))' % (x0,y0,x0-0.5,y0+0.5,x0,y0+1,x0+0.5,y0+0.5,x0,y0)))
        lyr.CreateFeature(f)
lyr.CommitTransaction()
So continuous diamond shaped polygons (at the beginning, I created straight
polygons, but for some reason, the rasterizing algorithm doesn't manage to
draw such polygons, but that's a totally unrelated issue)
And then:
 gdal_rasterize -sql "select * from world_diamonds where st_intersects(wkb_geometry, ST_GeometryFromText('POLYGON((-180 -90,-180 90,180 90,180 -90,-180 -90))',4326))"  \
	 "pg:dbname=autotest"  out.tif -burn 255 -ts 4000 2000  -a_srs EPSG:4326 -te -180 -90 180 90
And the output looks good with both gdal 1.11 branch (haven't tested with 1.11.0 but
there was no significant change in the PG driver) and trunk.
Could you try the above ?
Compiled in DEBUG mode, I can see many
"PG: PQexecParams(FETCH 500 in OGRPGLayerReader0x2316c50) = PGRES_TUPLES_OK, ntuples = 500"
traces as expected. I don't understand why in your use case it fails at the first FETCH.
Could you try compiling GDAL with ./configure --enable-debug
so as to have more verbose traces in the PG driver ?
Even
Le lundi 09 février 2015 16:37:20, Graeme B. Bell a écrit :
> TLDR;
> gdal_rasterize has begun silently producing wrong output at least since
> GDAL 1.11.0. Whenever  >500 polygons are present in the database query
> result (and perhaps under other circumstances), only 500 will be drawn.
> Hi,
> I am rasterizing many maps and areas of maps in SRID 25833 using
> gdal_rasterize with a postgis database.
> When I use GDAL 1.11, the output is missing much of the data, despite
> gdal_rasterize reporting completing successfully. With GDAL 1.09 and GDAL
> 1.10, the output is correct and complete and identical.
> I'm posting here to gather more information about the bug and also to raise
> an alarm for anyone using postgis/gdal_rasterize (1.11) in their data
> workflow over the last year.
> Background of bug
> Versions:
> POSTGIS="2.1.5 r13152" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
> March 2012" GDAL="GDAL 1.11.0, released 2014/04/16"    (from EPEL RPM)
> A. The source table in postgis is registered in geometry_columns correctly.
> B. I run this command in Centos linux.
> gdal_rasterize -te 1060000 7865000 1120000 7940000 -a jord -init 255 -tr
> 100 100 -a_nodata 255 -a_srs 'EPSG:25833' -co 'TILED=YES' -co
> 'BIGTIFF=IF_SAFER' -co 'COMPRESS=PACKBITS' -co 'PREDICTOR=1' -co
> 'ZLEVEL=1' -ot Byte PG:"host=XXXX'' dbname='XXXX' user='XXXX'
> password='XXXX' tables='XXXX'" -sql "SELECT xxxx FROM xxxx WHERE
> st_intersects(geo, ST_GeometryFromText('POLYGON((1060000 7865000,1060000
> 7940000,1120000 7940000, 1120000 7865000, 1060000 7865000))',25833)) "
> xxxx.tif
> C. The SQL query (-sql), when run directly on postgres with COUNT(),
> produces this output.
>  count
>   3959
> (1 row)
> D. GDAL 1.9.2 and GDAL 1.10.0 produce a TIF file of 12238 bytes which is
> visually complete.
> E. GDAL 1.11.0 produces a TIF file of 10920 bytes which is missing many
> polygons.
> F. Console output from gdal_rasterize in all 3 cases is as follows;
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> G. PG server log output for GDAL 1.9.2 and GDAL 1.10.0
> (nothing...)
> PG server log output for GDAL 1.11.0
> < 2015-02-09 13:52:11.720 CET >STATEMENT:  FETCH 500 in
> OGRPGLayerReader0xd5ce50 < 2015-02-09 13:52:11.720 CET >ERROR:  cursor
> "ogrpglayerreader0xd5ce50" does not exist < 2015-02-09 13:52:11.720 CET
> >STATEMENT:  CLOSE OGRPGLayerReader0xd5ce50 < 2015-02-09 13:52:18.657 CET
> >ERROR:  cursor "ogrpglayerreader0x1fd8e50" does not exist
> H. Debug mode output for GDAL 1.11.0
> OGR: OGROpen(...) succeeded as PostgreSQL.
> GDAL: QuietDelete(xxxx.tif) invoking Delete()
> GDAL: GDALOpen(xxxx.tif, this=0x259a8f0) succeeds as GTiff.
> GDAL: GDALDefaultOverviews::OverviewScan()
> GDAL: GDALClose(xxxx.tif, this=0x259a8f0)
> GDAL: GDALDriver::Create(GTiff,xxxx.tif,600,750,1,Byte,0x25744e0)
> PG: Primary key name (FID): gid
> PG: Using column 'gid' as FID for table 'xxxx_25833'
> GDAL: Rasterizer operating on 1 swaths of 750 scanlines.
> PG: 500 features read on layer 'sql_statement'.
> GDAL: GDALClose(xxxx.tif, this=0x2598930)
> I. Debug mode output for GDAL 1.10.0
> OGR: OGROpen(xxxx) succeeded as PostgreSQL.
> GDAL: QuietDelete(xxxx) invoking Delete()
> GDAL: GDALOpen(xxxx) succeeds as GTiff.
> GDAL: GDALClose(xxxx.tif, this=0xeb5030)
> GDAL: GDALDriver::Create(GTiff,xxxx.tif,600,750,1,Byte,0xe8ede0)
> PG: Using column 'gid' as FID for table 'dmk_25833'
> PG: Layer 'xxxx_25833' geometry type: GEOMETRY:Unknown (any), Dim=2
> PG: 3959 features read on layer 'sql_statement'.
> GDAL: GDALClose(xxxx.tif, this=0xeb2fd0)
> As well as local unix sockets I've tested TCP connections to a remote PG
> database from GDAL1.10 and GDAL1.11 clients, and I've tested with other
> data layers. Every time, I'm getting the same problem e.g. 500 features
> out 8000.
> Has anyone else experienced anything similar?
> I've spent some time looking through the source but I wasn't able to
> determine exactly where the problem is occuring. It seems to somehow be
> related to the select page size (500 rows) being used in place of the
> total feature count; or perhaps some logic mistake causing the reads to
> finish after 1 page is complete.
> Graeme Bell
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
