[gdal-dev] Hidden regression in GDAL 1.11.0 - gdal_rasterize with postgis silently fails to render many polygons.
Even Rouault even.rouault at spatialys.com
Mon Feb 9 10:23:26 PST 2015
Graeme,
I confirm. This is the result of a subtile interaction of tables= , SQL request
and SRS resolving. The PG driver has become quite subtile...
Traced in http://trac.osgeo.org/gdal/ticket/5837 and now fixed.
As a workaround you could use a view that does the the "select * from
world_diamonds where st_intersects(wkb_geometry,
ST_GeometryFromText('POLYGON((-180 -90,-180 90,180 90,180 -90,-180
-90))',4326))" and use the view name with the -l parameter of gdal_rasterize
(he bug doesn't occur if using a straight layer name)
gdal_rasterize could/should be improved as well to set a spatial filter
automatically. That way you could just use the layer name.
Anyway I guess this will be a good reason to issue a 1.11.2RC2 with the fix.
Even
> Hi Even,  thanks very much for this.
> I setup the DB with    createdb autotest; echo "create extension postgis;"
> | psql autotest
> Then I did your test. Annoyingly, it worked fine!
> Then I redid my own tests. They still didn't work.
> So I varied all the parameters between the two examples until I found the
> one that triggers it.
> GOT IT! :-)
> It's the tables parameter that triggers it. I have used 'tables' since 2012
> to avoid doing a scan of the DB because we have a LOT of tables here (e.g.
> >1 TB of postgis data).
> gdal_rasterize -sql "select * from world_diamonds where
> st_intersects(wkb_geometry, ST_GeometryFromText('POLYGON((-180 -90,-180
> 90,180 90,180 -90,-180 -90))',4326))"   "pg:dbname=autotest"  out.tif
> -burn 255 -ts 4000 2000  -a_srs EPSG:4326 -te -180 -90 180 90 --debug ON
> PG: DBName="autotest"
> PG: PostgreSQL version string : 'PostgreSQL 9.3.5 on
> x86_64-unknown-linux-gnu, compiled by gcc (GCC) 4.8.2 20140120 (Red Hat
> 4.8.2-16), 64-bit' PG: PostGIS version string : '2.1 USE_GEOS=1 USE_PROJ=1
> USE_STATS=1' OGR: OGROpen(pg:dbname=autotest/0x9f65f0) succeeded as
> PostgreSQL. GDAL: QuietDelete(out.tif) invoking Delete()
> GDAL: GDALOpen(out.tif, this=0xa292e0) succeeds as GTiff.
> GDAL: GDALDefaultOverviews::OverviewScan()
> GDAL: GDALClose(out.tif, this=0xa292e0)
> GDAL: GDALDriver::Create(GTiff,out.tif,4000,2000,1,Float64,(nil))
> GDAL: Rasterizer operating on 7 swaths of 312 scanlines.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> PG: 64800 features read on layer 'sql_statement'.
> <------------- GDAL: GDALClose(out.tif, this=0xa283d0)
> whereas
> tables='world_diamonds'"  out.tif -burn 255 -ts 4000 2000  -a_srs
> tables='world_diamonds'/0x1668a10) succeeded as PostgreSQL. GDAL:
> GDAL: GDALOpen(out.tif, this=0x1688b40) succeeds as GTiff.
> GDAL: GDALClose(out.tif, this=0x1688b40)
> GDAL: GDALDriver::Create(GTiff,out.tif,36,18,1,Float64,(nil))
> PG: Primary key name (FID): ogc_fid
> PG: Using column 'ogc_fid' as FID for table 'world_diamonds'
> GDAL: Rasterizer operating on 1 swaths of 18 scanlines.
> PG: 500 features read on layer 'sql_statement'.
> <------------- GDAL: GDALClose(out.tif, this=0x1686720)
> Graeme Bell
> On 09 Feb 2015, at 18:01, Even Rouault <even.rouault at spatialys.com> wrote:
> > Graeme,
> > I tried to reproduce your issue as close as possible but couldn't
> > replicate the bug.
> > I create a postgis layer with 360x180 polygons with the following Python
> > script
> > from osgeo import ogr
> > from osgeo import osr
> > ds = ogr.Open('pg:dbname=autotest')
> > srs = osr.SpatialReference()
> > srs.ImportFromEPSG(4326)
> > lyr = ds.CreateLayer('world_diamonds', geom_type = ogr.wkbPolygon, srs =
> > srs, options = ['OVERWRITE=YES']) lyr.StartTransaction()
> > for y in range(180):
> >    for x in range(360):
> >        f = ogr.Feature(lyr.GetLayerDefn())
> >        x0 = x - 180 + 0.5
> >        y0 = 90 - y - 1
> >        f.SetGeometry(ogr.CreateGeometryFromWkt('POLYGON((%f %f,%f %f,%f
> >        %f,%f %f,%f %f))' %
> >        (x0,y0,x0-0.5,y0+0.5,x0,y0+1,x0+0.5,y0+0.5,x0,y0)))
> >        lyr.CreateFeature(f)
> > lyr.CommitTransaction()
> > So continuous diamond shaped polygons (at the beginning, I created
> > straight polygons, but for some reason, the rasterizing algorithm
> > doesn't manage to draw such polygons, but that's a totally unrelated
> > issue)
> > And then:
> > 90,180 90,180 -90,-180 -90))',4326))"  \
> > 	 "pg:dbname=autotest"  out.tif -burn 255 -ts 4000 2000  -a_srs EPSG:4326
> > 	 -te -180 -90 180 90
> > And the output looks good with both gdal 1.11 branch (haven't tested with
> > 1.11.0 but there was no significant change in the PG driver) and trunk.
> > Could you try the above ?
> > Compiled in DEBUG mode, I can see many
> > "PG: PQexecParams(FETCH 500 in OGRPGLayerReader0x2316c50) =
> > PGRES_TUPLES_OK, ntuples = 500" traces as expected. I don't understand
> > why in your use case it fails at the first FETCH.
> > Could you try compiling GDAL with ./configure --enable-debug
> > so as to have more verbose traces in the PG driver ?
> > Even
> > Le lundi 09 février 2015 16:37:20, Graeme B. Bell a écrit :
> >> TLDR;
> >> gdal_rasterize has begun silently producing wrong output at least since
> >> GDAL 1.11.0. Whenever  >500 polygons are present in the database query
> >> result (and perhaps under other circumstances), only 500 will be drawn.
> >> Hi,
> >> I am rasterizing many maps and areas of maps in SRID 25833 using
> >> gdal_rasterize with a postgis database.
> >> When I use GDAL 1.11, the output is missing much of the data, despite
> >> gdal_rasterize reporting completing successfully. With GDAL 1.09 and
> >> GDAL 1.10, the output is correct and complete and identical.
> >> I'm posting here to gather more information about the bug and also to
> >> raise an alarm for anyone using postgis/gdal_rasterize (1.11) in their
> >> data workflow over the last year.
> >> Background of bug
> >> Versions:
> >> POSTGIS="2.1.5 r13152" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
> >> March 2012" GDAL="GDAL 1.11.0, released 2014/04/16"    (from EPEL RPM)
> >> A. The source table in postgis is registered in geometry_columns
> >> correctly.
> >> B. I run this command in Centos linux.
> >> gdal_rasterize -te 1060000 7865000 1120000 7940000 -a jord -init 255 -tr
> >> 100 100 -a_nodata 255 -a_srs 'EPSG:25833' -co 'TILED=YES' -co
> >> 'BIGTIFF=IF_SAFER' -co 'COMPRESS=PACKBITS' -co 'PREDICTOR=1' -co
> >> 'ZLEVEL=1' -ot Byte PG:"host=XXXX'' dbname='XXXX' user='XXXX'
> >> password='XXXX' tables='XXXX'" -sql "SELECT xxxx FROM xxxx WHERE
> >> st_intersects(geo, ST_GeometryFromText('POLYGON((1060000 7865000,1060000
> >> 7940000,1120000 7940000, 1120000 7865000, 1060000 7865000))',25833)) "
> >> xxxx.tif
> >> C. The SQL query (-sql), when run directly on postgres with COUNT(),
> >> produces this output.
> >> count
> >>  3959
> >> (1 row)
> >> D. GDAL 1.9.2 and GDAL 1.10.0 produce a TIF file of 12238 bytes which is
> >> visually complete.
> >> E. GDAL 1.11.0 produces a TIF file of 10920 bytes which is missing many
> >> polygons.
> >> F. Console output from gdal_rasterize in all 3 cases is as follows;
> >> G. PG server log output for GDAL 1.9.2 and GDAL 1.10.0
> >> (nothing...)
> >> PG server log output for GDAL 1.11.0
> >> < 2015-02-09 13:52:11.720 CET >STATEMENT:  FETCH 500 in
> >> OGRPGLayerReader0xd5ce50 < 2015-02-09 13:52:11.720 CET >ERROR:  cursor
> >> "ogrpglayerreader0xd5ce50" does not exist < 2015-02-09 13:52:11.720 CET
> >>> STATEMENT:  CLOSE OGRPGLayerReader0xd5ce50 < 2015-02-09 13:52:18.657
> >>> CET ERROR:  cursor "ogrpglayerreader0x1fd8e50" does not exist
> >> H. Debug mode output for GDAL 1.11.0
> >> OGR: OGROpen(...) succeeded as PostgreSQL.
> >> GDAL: QuietDelete(xxxx.tif) invoking Delete()
> >> GDAL: GDALOpen(xxxx.tif, this=0x259a8f0) succeeds as GTiff.
> >> GDAL: GDALClose(xxxx.tif, this=0x259a8f0)
> >> GDAL: GDALDriver::Create(GTiff,xxxx.tif,600,750,1,Byte,0x25744e0)
> >> PG: Primary key name (FID): gid
> >> PG: Using column 'gid' as FID for table 'xxxx_25833'
> >> GDAL: Rasterizer operating on 1 swaths of 750 scanlines.
> >> GDAL: GDALClose(xxxx.tif, this=0x2598930)
> >> I. Debug mode output for GDAL 1.10.0
> >> OGR: OGROpen(xxxx) succeeded as PostgreSQL.
> >> GDAL: QuietDelete(xxxx) invoking Delete()
> >> GDAL: GDALOpen(xxxx) succeeds as GTiff.
> >> GDAL: GDALClose(xxxx.tif, this=0xeb5030)
> >> GDAL: GDALDriver::Create(GTiff,xxxx.tif,600,750,1,Byte,0xe8ede0)
> >> PG: Using column 'gid' as FID for table 'dmk_25833'
> >> PG: Layer 'xxxx_25833' geometry type: GEOMETRY:Unknown (any), Dim=2
> >> PG: 3959 features read on layer 'sql_statement'.
> >> GDAL: GDALClose(xxxx.tif, this=0xeb2fd0)
> >> As well as local unix sockets I've tested TCP connections to a remote PG
> >> database from GDAL1.10 and GDAL1.11 clients, and I've tested with other
> >> data layers. Every time, I'm getting the same problem e.g. 500 features
> >> out 8000.
> >> Has anyone else experienced anything similar?
> >> I've spent some time looking through the source but I wasn't able to
> >> determine exactly where the problem is occuring. It seems to somehow be
> >> related to the select page size (500 rows) being used in place of the
> >> total feature count; or perhaps some logic mistake causing the reads to
> >> finish after 1 page is complete.
> >> Graeme Bell
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
