[gdal-dev] Wrong number or type of arguments for overloaded function 'CoordinateTransformation_TransformPoint'
Kyle Shannon kyle at pobox.com
Tue Feb 10 10:46:23 PST 2015
Brendan,
On 02/10/2015 11:13 AM, DeTracey, Brendan wrote:
> The should be on the path. (Very strange that the Anaconda installer dumped a copy in its root directory.)
> C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>echo %PATH%
> C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\MATLAB\R2012a\bin;C:\Program Files (x86)\MATLAB\R2010bSP1\bin;C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda;C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\Scripts;
> C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>dir proj.*
>   Volume in drive C is OSDisk
>   Volume Serial Number is 7A59-3F7E
>   Directory of C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda
> 06/02/2015  07:45 AM           369,152 proj.dll
> 06/02/2015  07:45 AM            19,456 proj.exe
>                 2 File(s)        388,608 bytes
>                 0 Dir(s)  76,317,147,136 bytes free
> C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>proj.exe
> Rel. 4.8.0, 6 March 2012
> usage: proj.exe [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
> I also tried adding to the script :
> gdal.SetConfigOption('PROJSO', 'C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\proj.dll')
> This also did not work.
>> -----Original Message-----
>> From: Even Rouault [mailto:even.rouault at spatialys.com]
>> Sent: February-10-15 11:55 AM
>> To: gdal-dev at lists.osgeo.org
>> Cc: DeTracey, Brendan
>> Subject: Re: [gdal-dev] Wrong number or type of arguments for overloaded
>> Le mardi 10 février 2015 16:27:54, DeTracey, Brendan a écrit :
>>> Hi,
>>> I am using the GDAL python bindings via Windows 64 bit Anaconda, but I
>>> am getting an error when I try to run one of the GDAL sample scripts,
>>> tolatlong.py e.g.
>>> E:\parse_cis>python tolatlong.py 0 0 temp.tif Traceback (most recent
>>> call last):
>>>    File "tolatlong.py", line 106, in <module>
>>>      (int, lat, height) = ct.TransformPoint(X, Y)
>>>    File
>>> "C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\lib\site-packages
>>> \osg eo\osr.py", line 757, in TransformPoint return
>>> _osr.CoordinateTransformation_TransformPoint(self, *args)
>>> NotImplementedError: Wrong number or type of arguments for overloaded
>>> function 'CoordinateTransformation_TransformPoint'. Possible C/C++
>>> prototypes are:
>>>      OSRCoordinateTransformationShadow::TransformPoint(double [3])
>>> [3],double,double,double)
>>> When I google this error I find it might be related to GDAL not
>>> finding Proj (https://github.com/avalentino/gsdview/issues/89). Could
>>> someone please verify that this would be the source of this error? I
>>> have installed Proj under Anaconda and am trying to rule out whether
>>> it is a problem with Anaconda or GDAL.
>> Yes, it seems very likely this is due to proj missing. Check that proj.dll is
>> available in one of the paths in the PATH.
>>> Thanks,
>>> Brendan
>>> gdal-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Spatialys - Geospatial professional services http://www.spatialys.com
Is GDAL_DATA set?  I seem to remember that error if it was missing.
Just a guess though...
kss
Kyle
