[gdal-dev] reading postgis xyzm with ogr2ogr
Paul Ramsey pramsey at cleverelephant.ca
Wed Feb 11 09:55:55 PST 2015
You could use the OGR sql query option to wrap your geometry call in a force2d or force3d function call in PostGIS?
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On February 11, 2015 at 9:54:07 AM, Duarte Carreira (dncarreira at gmail.com) wrote:
Hi there.
I’m trying to figure out how to read xyzm geometries from postgis with ogr2ogr, if at all possible.
I get the usual "is not supported" error:
ERROR 1: Reading EWKB with 4-dimensional coordinates (XYZM) is not supported
But reading old tickets I get the idea there is a way to read and just ignore the 4th dimension, instead of getting null geometries.
For instance:
http://trac.osgeo.org/gdal/ticket/1323
From 8 years ago(!), says:
The problem does not occur if a layer is accessed using
OGRPGDataSource::GetLayerByname()
Then, geometry is read in EWKT form and parsed correctly without any errors but M coordinate is omitted.
Can this be done using og2ogr?
Thanks,
Duarte
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150211/4c98d970/attachment-0001.html>
