[gdal-dev] reading postgis xyzm with ogr2ogr
Duarte Carreira dncarreira at gmail.com
Thu Feb 12 01:52:57 PST 2015
Hi. I am not that desperate ;)
I was trying to figure out if the command ogr2ogr could use the hint in the
ticket, by using the ewkt...
Thanks,
Duarte
On Thu, Feb 12, 2015 at 9:49 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> depending on how desperate you are you could :
>  - use simple COPY statement to export you LINESTRINGZM from database
>  - use python + python-ogr and manually create a X Y Z M file
>  - use python + shapely
> In all case you can wrap it into a command line executable, liek ogr2ogr.
> Cheers,
> Rémi-C
> 2015-02-11 19:23 GMT+01:00 Duarte Carreira <dncarreira at gmail.com>:
>> Thanks Paul.
>> Yes, but I'm trying to export all tables from a schema, so I don't state
>> the names of the tables. I think using sql would require 1 comand per
>> table, right?
>> So my command is something like this:
>> ogr2ogr -progress PG:"dbname='postgis'
>> active_schema=schema1 schemas=schema1 <connectioninfo>" -f "SQLite"
>> mydb.sqlite   ....
>> I was hoping for a magic parameter to avoid the xyzm error...
>> On Wed, Feb 11, 2015 at 5:55 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> You could use the OGR sql query option to wrap your geometry call in a
>>> force2d or force3d function call in PostGIS?
>>> Paul Ramsey
>>> http://cleverelephant.ca
>>> http://postgis.net
>>> On February 11, 2015 at 9:54:07 AM, Duarte Carreira (
>>> dncarreira at gmail.com) wrote:
>>>  Hi there.
>>> I’m trying to figure out how to read xyzm geometries from postgis with
>>> ogr2ogr, if at all possible.
>>> I get the usual "is not supported" error:
>>> ERROR 1: Reading EWKB with 4-dimensional coordinates (XYZM) is not
>>> supported
>>> But reading old tickets I get the idea there is a way to read and just
>>> ignore the 4th dimension, instead of getting null geometries.
>>> For instance:
>>> http://trac.osgeo.org/gdal/ticket/1323
>>> From 8 years ago(!), says:
>>> The problem does not occur if a layer is accessed using
>>> OGRPGDataSource::GetLayerByname()
>>> Then, geometry is read in EWKT form and parsed correctly without any
>>> errors but M coordinate is omitted.
>>> Can this be done using og2ogr?
>>> Thanks,
>>> Duarte
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150212/5ef60953/attachment.html>
