[gdal-dev] SetNoDataValue on Memory Raster
Even Rouault even.rouault at spatialys.com
Thu Feb 12 11:26:22 PST 2015
Brendan,
> Using the Python bindings, I am having trouble getting a memory raster to
> respect SetNoDataValue. It works with a GeoTiff(if I close and then reopen
> it for reading), I presume because everything gets written when the raster
> is closed. My code:
> conc_band = t_ds.GetRasterBand(1)
> conc_band.SetNoDataValue(-32768)
SetNoDataValue() only sets a parameter to indicate which value should be
considered as nodata, but doesn't change the pixel values themselves.
Try adding
conc_band.Fill(-32768)
> thick_band = t_ds.GetRasterBand(2)
> thick_band.SetNoDataValue(-32768)
Idem, add
thick_band.Fill(-32768)
> gdal.RasterizeLayer(t_ds, [1], layer, options=['ATTRIBUTE=CONC'])
> gdal.RasterizeLayer(t_ds, [2], layer, options=['ATTRIBUTE=THICK'])
> #t_ds.FlushCache()
> conc = conc_band.ReadAsArray()
> thick = thick_band.ReadAsArray()
> When I ReadAsArray, I get a 0 instead of -32768. I tried FlushCache
> (commented out above) but it did not help. How do I force the raster in
> memory to update before I reaqd it?
Even
http://www.spatialys.com
