[gdal-dev] VRT creation from Python, adding existing geotiff as bands
Even Rouault even.rouault at spatialys.com
Mon Feb 16 05:27:09 PST 2015
Rémi,
> Hey dear list,
> this is my first post here,
> so sorry if I'm asking something obvious.
> (I noticed the 2 previous mail thread regarding python and VRT).
> I wrote python functions to convert a numpy structured array to several
> gdal rasters.
> A numpy structured array is a 2D pixel array, but each pixel has in fact
> several values of possibly different type (like band).
> For instance a pixel dtype can be [float32,uint16,Float64].
> I want to convert this array to raster(s).
> First I tried to create one raster with several bands,
> but GeoTiff cannot handle bands with different pixel type (or I didn't find
> how).
This is a limitation of the TIFF format, and most formats actually.
> I concluded that I must create several rasters, and put them all as bands
> in a VRT.
> So far I have been able to create several geoTiff raster of various type
> corresponding to the numpy structured array.
> Now, I don't know how to create from python the VRT that unites all this
> rasters.
> When I try to write in a VRT raster band I get errors.
"write" what exactly : the VRT XML/structure or the pixel values ?
You can partially create VRT files with a mix of API and XML. See for example
the following extract from autotest/gdrivers/vrtderived.py
    filename = 'tmp/derived.vrt'
    vrt_ds = gdal.GetDriverByName('VRT').Create(filename, 50, 50, 0)
    options = [
        'subClass=VRTDerivedRasterBand',  # ==> You would likely need
VRTSourcedRasterBand heere
    vrt_ds.AddBand(gdal.GDT_Byte, options)
    simpleSourceXML = '''    <SimpleSource>
      <SourceFilename>data/byte.tif</SourceFilename>
      <SourceBand>1</SourceBand>
    </SimpleSource>'''
    md = {}
    md['source_0'] = simpleSourceXML
    vrt_ds.GetRasterBand(1).SetMetadata(md, 'vrt_sources')
    md_read = vrt_ds.GetRasterBand(1).GetMetadata('vrt_sources')
    vrt_ds = None
This is a bit documented in the VRT tutorial. See
http://gdal.org/gdal_vrttut.html (search "In this example a virtual dataset is
created with the Create() method, and adding bands and sources
programmatically" in the page)
Note that datasets with bands of different datatypes are not always well
supported in the various algorithms, utilities or API (mostly due to the lack
of formats that support it and the ensuing lack of testing of such situations)
Even
http://www.spatialys.com
