[gdal-dev] Patch to improve libjpeg compatibility on gdal 1.11
Even Rouault even.rouault at spatialys.com
Tue Feb 17 08:00:03 PST 2015
David,
Hum I can see http://trac.osgeo.org/gdal/changeset/27926#file1 was accidentaly
committed with an unrelated commit (and should probably be related). When
digging a bit, it was related to experiments I did with libjpegv9 (not 9a)
which dates back to 2013 whereas 9a is from 2014, and has a different section
in jmorecfg.h related to boolean/TRUE/FALSE (and I see I also manually edited
jmorecfg.h of that older version)
Where I'm confused now is that I don't need any patch in the 1.11 branch to
compile against 9a...
The releavant extract of the output of g++ -E on libjpeg_io.cpp is
# 309 "/home/even/install-jpeg-9a/include/jmorecfg.h"
typedef int boolean;
so it doesn't use at all the "typedef enum { FALSE = 0, TRUE = 1 } boolean;"
thing.
Even
> Hey,
> the attached patch against the 1.11 branch from svn is basically a backport
> from the 2.0 branch.
> It fixes a namespace problem in
> frmts/pcidsk/sdk/core/libjpeg_io.cpp
> when building gdal against a current libjpeg version (newer than v6b,
> tested with v9a).
> The technical reason is that libjpeg v6b typedefs boolean as int and uses
> macros for TRUE and FALSE, which is namespace agnostic. Newer versions of
> libjpeg typedef boolean as enum with values TRUE and FALSE, which do not
> propagate into other namespaces. Therefor, the use of TRUE inside C++
> methods fails.
> I encountered the problem when trying to build gdal 1.11.1 against libjpeg
> v9a.
> Please review.
> Thanks,
> David
http://www.spatialys.com
